I made a spreadsheet in Lotus 1-2-3 to compare engine RPM vs. MPH between the new Genesis 2.0T & 3.8, new V6 Camaro, V6 Mustang and previous V6 Mustang's I've owned. Also added other Manual Transmission / RWD cars currently available as well as 2009 MINI Clubman S, and 2008 Tiburon models. Also did 3 collums with changed rear gears in the 2.0T & 3.8 using 3.8 gears in the 2.0T and 4.6 Senan gears in both the 2.0T & 3.8. All in all on 2 landscape pages, info on 18 different cars can be compared.
Spreadsheet does all the math, all you need to change to check a different car is the transmission gear ratios, final drive ratio, tire section height, and rim diameter.
Also have rows for Vehicle, HP, Torque, Curb wgt., lb./HP ratio, EPA mileage, fuel tank size, and range per tank that you can edit for each car you want to compare.
Not sure if this type of file can be attached or inserted in a thread. If anyone is familiar with Lotus 1-2-3 and wants a copy of this spreadsheet to play with (or would know how to post it in the forum), PM me with your e-mail address and I'll send you a copy.
Doug
Doug
