1 - 20 of 47 Posts
1. Head lamp (Highbeam) - H1 55w
2. Projection Head lamp (Lowbeam) - H11B
or HID Head lamp (Lowbeam) - D1S 35w
3. Front turn signal lamp - 2357 28/8w amber; (note: 1157 replacement bulbs will fit right in and work just as well)
4. Front side marker - 194 5w clear
5. Front fog lamp - 881 27w; (note: the 881 is a single filament bulb with a PGJ13 base same as 886 50w, 889 27w, 894 38w, 896 38w, 898 38w)
6. Side mirror turn signal lamp -
7. High mounted stop lamp -
8. Tail lamp (Inside - 1 prong) - 1157 27/8w clear
9. Stop lamp/Tail lamp (Outside - 2 prong) - 1157 27/8w clear
10. Rear turn signal lamp - 1156 27w amber
11. Back up lamp - 921 16w clear
12. Rear side marker - 921 clear
13. Overhead console lamp (Map/Dome) - 921 10w
14. Luggage lamp - 194 festoon 5w
Vanity mirror - 194 festoon 5w
License plate - 194 festoon
Courtesy lights (under doors) - 194/168
Glove box - 194 festoon
FWIW I have used some '100w" hi beams. They are really 70W actual current draw. Work better than the 55w and no overheating problems. You can also get some back up lamps that are a couple watts brighter (18w vs 16w OEM) at the hardware store in the outside lighting yard light section.
I also see they make fog lamps that are a direct fit that are higher wattage. PGJ13 base same as the 881, 27w. 886 50w, 889 27w, 894 38w, 896 38w, 898 38w.
By the way, I used your chart and purchased some replacement bulbs for my Gen Coupe. My coupe did have the 1156 bulb. I didn't check before attempting to replace them. The connecting tabs are different and I had to slightly force the replacements so they would fit. They are working though. Maybe the cars in the 'States' have different bulbs.
So, as a complete n00b to this, how exactly does one go about looking for replacements? Do you walk into an auto parts store and ask for the model(s) listed in the OP, or do the models change with bulb make? What are some good, commonly-available brands?
In particular, I would really like to find a higher wattage (brighter) replacement for my GC's high beams. They don't seem very good at all, especially on these really dark winter nights.
Bulb sizes are the same regardless of the company - the only thing they might do is add suffix letters like if you had a bulb that was 921 in size ... you might find 921ST where the ST is some tweak that particular bulb has from whatever the company is (specifically I think ST means Silverstar if I remember right). If you go to a local auto part store they will not have much of anything better than Sylvania Silverstars which are not half bad but they are halogen - they have been good to me for years. They have very bright white light and I had a set of Silverstar headlights last over 5 years in my truck that I drove daily. If you want LED bulbs the best you will likely find at one of those stores as far as brand is APC. You can find better LEDs from sites online but I would first look at vids of how other cars with the same model bulbs work and how the bulbs look - there are many videos out there. Diode Dynamics is having a sale on the 27th for one day and the prices are good, but, as I said try to find some video examples of the exact types/styles you're thinking of buying.
Discussion Starter · #10 ·
No worries. That one was a pretty easy catch (not easy to mistake one bulb for two). Is the model of bulb still correct?
Discussion Starter · #12 ·
I took all the bulbs out of the holders to get the actual part numbers on my Track 2L with HIDs and fogs.
Here they are.
Front
Lo Beam-HID DS1 35w Orsam from Germany
Hi beam- H1 55w
Turn/park-2357 28/8w amber
Side marker 194 5w clear
Fog 881 27w, note: the 881 is a single filament bulb with a PGJ13 base same as 886 50w, 889 27w, 894 38w, 896 38w, 898 38w
Map/Dome 921 10w
Vanity festoon 5w
Back
Turn 1156 27w clear
Outside brake/tail 1157 27/6w clear
Backup 921 16w clear
Inside brake/tail 1157 27/8w clear
Trunk festoon 5w
If anyone's having a hard time finding replacement bulbs, we just started carrying Halo Lights. They're Japanese made HID, Halogen and LED bulbs, they pull the stock wattage, but their manufacturing technology makes them produce more light with that stock wattage, so, for example, a 55w bulb produces a light equivalent of an 85w bulb. They are more expensive than what you'll find at your local parts store, but that's due to the manufacturing process that makes them perform better. They come in some pretty sweet colors. We're running an intro special on them through Jan 5th of 25% off. Use coupon code GENHALO25. You can find them on our main site, but HaloLightStore.com has a pretty cool setup to let you explore all the bulb colors.
What Temperature HIDs are the stock low beams on the Track 3.8?
Discussion Starter · #20 ·
1 - 20 of 47 Posts
