"This issue has been touched upon on the boards before, but it'll come up more often especially with people buying a base model car without HID.
I'm a big fan of HIDs, but I also cannot stand the "HID drop in" kits that are made out there. There's a lot of misinformation about them, and I've even gotten into arguments with vendors on other boards about beam patterns and cutoffs and whatnot. Simply put, a halogen housing with a xenon bulb will not light correctly. Here's a link to persue if you're interested. It explains pretty well why I'm not reluctant to call someone out if they go the cheap swap route.
Thinking about converting to HID?
Daniel Stern Lighting Consultancy and Supply
That all said, you CAN buy a proper projector housing and get a xenon bulb in place that gives a correct beam pattern and cutoff. It's expensive and most of the time requires custom work, however."
I want to thank N2OInferno for writing this, I got it from gencoupe.com
