wow look at the exhaust!!!!!!!!!
+1....we noticed this when one of the Koreans changed their exaust & laid the old one out on the floor of their shop that is was squished in the middle & so restrictive.wow look at the exhaust!!!!!!!!!
+1...just manfild back exaust will help tremendously.WOW, that is great news I guess? Factory kills 33% flow. May need to just open that pipe first and see how it responds. I like that, REAL cheap and easy mod.
+1...you just listed my 1st stage of mods for my car...Mmmm 2.0t + exhaust + intake + injectors + tune = more boost, safer, and obviously a good bit more power? Can't wait...
This engine is under-rated & the car is an underdog, can't wait to show folks what it is capable of. :rofl:Hyundai Genesis Coupe: Hyundai Genesis Coupe 2.0-Liter Dynos Higher Than 210 HP
"Not only did they get 227 lb-ft of torque at the wheels, they got 197 HP when making the dyno runs in fourth gear. If we work backwards using the rule of thumb 15% driveline losses for RWD cars, we see the approximate output the turbo four is 261 lb-ft of torque and 226 HP at the flywheel. Roughly about 7% more horsepower and a whopping 17% more torque than Hyundai states. Either Edmunds got a goosed version or the customers will be happily getting more bang for their buck. "
Only 1 transmission available on 2.0t Track, 6sp M/TWhat tranny did they use? If they used the MT tranny they should have done a pull in 5th gear not 4th as that one is the 1:1 ratio... the manual in 4th is 1.233:1 and will show higher readings..
That's right I forgot about that, then this Dyno graph is not accurate at all of what the engine is making.. in fourth gear the engine/tranny is at a ~1.2:1 ratio, basically means the power readings from a dyno will read about 20% HIGHER than they should... They should have been doing the dyno run in fifth gear as it is at 1:1.. If i am missing something someone correct me.. but this I think is basic dyno testing 101...Only 1 transmission available on 2.0t Track, 6xp M/T
I'm no genius when comes to dynos or tuning, but every dyno pull I've seen seems to always be in a higher gear than 4th & what you just said makes sense as to why. Alright mighty tuners, an you confirm this for us.That's right I forgot about that, then this Dyno graph is not accurate at all of what the engine is making.. in fourth gear the engine/tranny is at a ~1.2:1 ratio, basically means the power readings from a dyno will read about 20% HIGHER than they should... They should have been doing the dyno run in fifth gear as it is at 1:1.. If i am missing something someone correct me.. but this I think is basic dyno testing 101...
