The Road to 35 MPG: Analysis From 2009—the Society of Automotive Engineers World Congress
At this year's SAE World Congress there is a sense of urgency and excitement in the air as the gathered automotive engineers begin to tackle what may be the toughest challenge yet: Dramatically increasing fuel economy in the U.S. The government's 35-mpg requirement that goes into effect in 2020 is a 30 percent jump from today's fuel-economy standard. Since a new car takes about four years to design, test, and bring to market, carmakers need to stay ahead of the technology curve. So how will automakers hit that target? Paul Najt, the Group Manager of GM's powertrain research lab said, "There's no silver bullet." Instead, small incremental improvements in all areas will add up to major savings. Here's how automakers will do it.
By Larry Webster
Published on: April 24, 2009
Engines
Expect to see smaller engines, with plenty of efficiency-boosting features. Variable valve timing and lift will become much more common, turbos will be used to offset power losses from smaller engines, and gradually more engine accessories like water and power-steering pumps will be electrically driven. New coatings and roller bearings will reduce engine friction. It's also very possible that we'll finally see camless, electromagnetically operated valves. Of course diesels and hybrids will make up an increasing part of the mix, but those options have cost penalties. Those powertrains "must have dramatic improvements in cost," says John German, from the International Council for Clean Transportation. His opinion is not universally shared, however. Asian manufacturers pointed to the low-cost Honda Insight Hybrid, while the Europeans seem to be banking on clean-diesel technology. John Juriga, the Director of Hyundai and Kia U.S. powertrain development, said that "every company has their own unique path."
Transmissions
Kiss the four-speed automatic goodbye. The coming trend will be more gears to obtain a larger ratio spread. More speeds means the engine doesn't have to work as hard, saving fuel. Double-clutch automated transmissions will become much more common. Look at VW: "Our seven-speed DSG transmission can produce 14 percent less CO2 than a six-speed automatic," says Norbert Krause, the director of VW's engineering and environment. And of course, engineers will attack friction, with the same strategies used on engines.
Chassis and Body
The consensus we heard from industry experts? Aerodynamic development has somewhat stalled in recent years. But that will quickly change. However, the improvements will be subtle and perhaps not easily recognizable. Air intakes will shrink and windows will become flush with the body. Also, aerodynamicists will pay particular attention to the vehicle underbody, which accounts for 10 to 20 percent of a car's drag. Expect to see larger underbody trays on all cars. And lower-rolling-resistance tires will become the norm rather than the exception.
Vehicle Weight
Few cars today weigh less than 3000 pounds and many weigh more than 2 tons, thanks to tougher crash requirements, ever-increasing feature content, and the general refinement provided by stiffer, heavier cars. While it might seem obvious that automakers must shed vehicle weight to improve fuel economy, opinions were split on just how much. John German didn't think there would be much difference in 2020, while Ford's chief technical officer Gerhard Schmidt believes that vehicle weight will drop by 250 to 750 pounds within the next decade. Weight savings, however, was clearly on the minds of everyone at the show. We attended one seminar at which a Honda engineer revealed how it reduced the weight of radio chassis by 30 percent by using carbon-fiber-impregnated plastic instead of sheet steel. Another engineer described the potential weight savings from plastic oil-filter modules. Material choices will be critical, and engineers will juggle cost with weight. Aluminum and thinner-gauge high-strength steel are sure to be major players in future body shells.
The Bottom Line
The through-line at all these seminars? Automakers do not expect the customer to absorb the cost penalty that many of these technologies necessitate. So the real challenge becomes how to combine the various detail improvements without making the cars more expensive. While some customers will buy a car simply because it saves fuel, those folks represent less than 5 percent of the market according to sources at the SAE congress. Most expect some kind of quick cost recovery for any fuel-saving measure. And with gas currently around two bucks a gallon, it would require years to claw back even an extra $1000 spent on a hybrid system.
Also, we don't expect to see cars dramatically shrink in size. There will be an infusion of quality small cars (Ford's upcoming Fiesta for one), but most of the industry leaders believe they can achieve the fuel-economy target without radically changing the vehicle fleet.
The year 2020, however, is just one stop along the road that will someday radically change the way we drive. There will be more EVs. But even the most optimistic forecast puts electrics at just 5 percent of the vehicle fleet in 2020. The holy grail, however remains a fuel-cell car powered by renewably generated hydrogen. We won't even guess when that might become a reality.
35 MPG Fuel Economy Standard - Society of Automotive Engineers Tackle Governments MPG Challenge - Popular Mechanics
By Larry Webster
Engines
Transmissions
Chassis and Body
Vehicle Weight
The Bottom Line
