Thanks to gencoupe.com
1. Disconnect the negative (-) battery terminal (A).
2. Remove the drain plug (A) and drain the engine coolant.
3. Remove the front muffler (A).
4. Disconnect the breather hose (A), vacuum hose (B). And remove the air duct (C) and air cleaner assembly (D).
Tightening torque :
Bolt : 7.8 ~ 9.8N.m (0.8 ~ 1.0kgf.m, 5.8 ~ 7.2lb-ft)
Clamp : 2.9~ 4.9N.m (0.3 ~ 0.5kgf.m, 2.1 ~ 3.6lb-ft)
5. Disconnect the intercooler inlet hose (A).
Tightening torque :
Bolt : 14.7 ~ 19.6N.m (1.5 ~ 2.0kgf.m, 10.8 ~ 14.4lb-ft)
Clamp : 4.9~ 6.8N.m (0.5 ~ 0.7kgf.m, 3.6 ~ 5.0lb-ft)
6. Remove the drive belt (A).
7. Remove the turbo control hoses (A).
8. Remove the power steering pump. (Refer to steering group)
9. Remove the steering pump bracket (A).
Tightening torque :
19.6~ 23.5N.m (2.0 ~ 2.4kgf.m, 13.4 ~ 17.4lb-ft)
10. Remove the exhaust manifold heat protector (A) and turbocharger heat protector (B).
Tightening torque :
7.8~ 11.8N.m (0.8 ~ 1.2kgf.m, 5.8 ~ 8.7lb-ft)
11. Remove the oxygen sensor connectors (A).
12. Remove the coolant hoses (A) and oil hoses (B) from turbocharger.
13. Remove the turbocharger stay bolt (A) and WCC stay bolt (B).
Tightening torque :
A: 49.0 ~ 53.9N.m (5.0 ~ 5.5kgf.m, 36.1 ~ 39.8lb-ft)
B: 8.6~ 27.4N.m (1.9 ~ 2.8kgf.m, 13.7 ~ 20.2lb-ft)
14. Remove the exhaust manifold & turbocharger assembly (A) and gasket.
Tightening torque :
