This thread has been locked. Please keep in mind the "test" in this video is not a scientific test and does not accurately show in any way how strong the rods are in normal operating conditions..Thanks
Watch the video, makes you wonder if they'll upgrade the con rods for the US market.
ÆÄ¿ö ÆÑÅ丮 R-BOOST.COM :: ³×À̹ö Ä«Æä
I'd like the input of the engine builders on this site to tell me what you think of the test. Seems impractical to test a con rod just by hitting it along an axis it that doesn't normally experience load on, but it's frightening to see it snap off so easily at the same time. :yikes:
Loose tanslation of the text:
This is Genesis Coupe connecting rod hammering test...
But...
The result..
Gencoupe suggested connecting rod..
Of course there's not going to be much problem at SungJung (?)..
Even if you raise the boost a little it has a very weak connecting rod.
You will see this if you see the movie clip..
It is even weaker than beta SungJung (?) connecting rod..
How can this break only with hitting it twice with a hammer?
GenCoupe should make stronger connecting rod as soon as possible so they will save the poor owners from having broken connecting rods and also damaged blocks..
Estimate power that it can handle: If they try hard 300HP?
Hammering place: Chun-ahn PIT-IN
Who did it: Of course, Chun-ahn PIT-IN President~
Civictd04
But...
The result..
Civictd04
